Hello Im nearing having my wood boiler connected and filled. I was hoping someone could expand on the "Boiler Chemical Intro" jebatty did in another thread. Im looking for where to purchase these raw chemicals hopefully locally )IE hardware store, grocery store, plumbing supply house...) and if not online. Also whats the 'Mixture of these for treatment....
O2 scavanger -
Sodium sulfite - used in water treatment as an oxygen scavenger agent, pH 9 - WHere do you purchase this locally, is it sold as a common household product as something else?? Also how much do you add for X amount of gallons of system water?
PH level and maintaining it - I know I saw it in a different thread but I cannot find it. WHat is the proper PH level and where can these chemicals be purchased locally typically.
Sodium carbonate (soda ash) - a relatively strong base in various settings; used as a pH regulator to maintain stable alkaline conditions; common additive to neutralize acid effects and raise pH
Trisodium phosphate - a highly water-soluble ionic salt; dissolved in water has an alkaline pH; used as an acidity regulator (buffering agent).
Sodium silica - soluble in water, producing an alkaline solution; binds to heavier molecules and precipitates them out of the water.
Someone else mentioned this stuff - “Treatment Solution 101™” from this site (broken link removed) which is $25 to treat 200 gallons. What does this actually do/doesnt really state what its function is.
Are there other All in one treatments that stablizes the PH level and scavenges oxygen?
Thanks
~ Phil
O2 scavanger -
Thanks
~ Phil
Multi metal cleaners are also available.
