bought a p61.. need help venting
highbody
30
North East CT
i bought a p61 used off craigslist.. the guy used it for 4 winters before upgrading to a bigger unit
he couldn't find the booklet at the time of sale but said when he comes across it he with mail it to me im trying to put the stove kitty corner in the basement(so we can utilize more space)
can the exhaust go at a 45 degree angle? what is the steepest angle i can go?
it says the flue size on the back of the stove is 3inch, i tried to used a 3 inch exhaust adapter and it wouldn't fit, the previous owner supplied me with 4 inch exhaust piping is that right??
its getting cold in the house and i need to get this figured out
go to www.harmanstoves.com
there you will find manuals for the stoves, either under products, or customer care.
hope this helps you out. i just went, and found the manuals under products,and they had one listed for the P61 A. i tried under customer care but a pop up stopped me, they had one listed for a P61.
If this unit has an igniter, it's a P61A
The manuals are on-line at the Harman site
45 will be fine. You can probably go 90 without a problem, but the manual will tell you what's acceptable
It should have a 3" outlet. All the Harman stoves do. See if there's a clean surface on the outlet. The original owner may have goobed (technical term) too much RTV on there to seal it.
Don't panic yet. It's only October & there's enough knowledge here to solve your issues!
so that stinks i cant use the pipe that the previous owner included with the stove because its 4 inch
aubushon hardware sells a double walled flexible pipe in 3 inch... should i buy that to make my install a bit easier?
i just d/l the harman manual.. thank you
Check the previous owner's venting to see if there is a 3-4" stove starter in the system.
aubushon hardware sells a double walled flexible pipe in 3 inch… should i buy that to make my install a bit easier?
Can you ID who the manufacturer of the vent is? If so, you'll have to see the Aubuchon stuff is compatible & approved
Any time...
they use dura vent.. the manager is a friend of mine and has had many stoves and is very knowledgeable i measured the inside of the steal pipe coming out of the stove.. inside diameter is 3 inches, but the outside measures 3 1/2inches, thats why the 3'' appliance adapter doesn't work
(broken link removed)
also made by duravent
