Breckwell Big E - Won't start up
Caric67
14
Reedsburg, WI
Hello!
I have a Breckwell Big E that is 3 years old. This past Spring I shut it down, cleaned it and unplugged it. I just replaced both of the gaskets on the combustion blower before attempting to start it up for the winter. When I plug it in, the green power light stays on for 5 seconds and then turns off. I have replaced the fuse on the control board to no avail and I have checked my electrical connections to the combustion blower. Any suggestions!?
Thank you!
Hello!
Thank you!
Double check the connection for your exhaust blower, maybe it isn't starting and engaging the vacuum switch.
I have checked all of my electrical connections and all are tight. Same issue, when I plug the stove in, the green power light on the control board goes out after 5 seconds and won't start. Where to next? Thank you!
