Joined the boards tonight, have been lurking however for the last 2 weeks and really could use some input/help. I am fairly detailed oriented, but haven't really seen anything definitive in terms of direction on this. The sum of my question is whether I can build out the depth of my fireplace by apprx 15". The main driver is we want to put base cabinets on each side of the fireplace which are apprx 12"deep. (see attached picture which shows the spirit of what we are thinking)
At present, the fire place brick sits proud of the basement foundation by apprx 4" (2nd picture) After I place the1.50" foam board insulation against the wall and my .50" sheet rock. The fireplace brick sits 2" proud, then of course after we add the 12" deep cabinets the cabinets would then sit 10" proud of the fireplace brick. This is what I am hopeful to change and would like to extend the depth of the fireplace apprx 15" from where it sits today. I would plan on using steel studs and Durock to accomplish this.
Measurements of current fireplace:
Opening 26.25 H
Width 33.50 W
Edge of opening to edge of fire place brick 12" (noted in pic below)
Depth measured at back of fireplace to the opening (taken from floor) 22"
As of now we are leaning towards the Supreme I-30 gas insert.
http://downloads.hearthnhome.com/installManuals/2206_901.pdf
By increasing the depth of the current fireplace by 15" as noted above, we would be increasing the depth from 22" to 37" (measuring from the back of fireplace at ground level). Will an insert fit into a opening this deep? Are their other considerations that I am not accounting for. Basically we would simply add 15" in depth to picture to the 3rd picture.
![[Hearth.com] Building out depth of fireplace [Hearth.com] Building out depth of fireplace](https://www.hearth.com/talk/data/attachments/223/223238-f6f8079eb16a46a9262f01cdeb91f775.jpg?hash=diOeYFRxHg)
Opening 26.25 H
Width 33.50 W
![[Hearth.com] Building out depth of fireplace [Hearth.com] Building out depth of fireplace](https://www.hearth.com/talk/data/attachments/223/223236-e26c5f04381600cf46a204c4ccccffdc.jpg?hash=sY8VtY7-YA)
![[Hearth.com] Building out depth of fireplace [Hearth.com] Building out depth of fireplace](https://www.hearth.com/talk/data/attachments/223/223237-db2fc755b9ac27642f66e2afaa7f56f3.jpg?hash=WroSu-CMqP)
