How to use please 😊Cleaning, restoring, applying protective coating on working stoves or salesman samples?? Or how to use them?
I hope that isn't your install. But for using burner covers it depends upon what heat you want. If you want the most heat you pull the cover to get direct heat on the pan
A bit more information would be helpful….I hope that isn't your install. But for using burner covers it depends upon what heat you want. If you want the most heat you pull the cover to get direct heat on the pan
“I hope that isn’t your install”. I’m sorry, I don’t know what that means.About what?
Inadequate hearth protection. Inadequate clearances.“I hope that isn’t your install”. I’m sorry, I don’t know what that means.
Would you please be a little less vague?Inadequate hearth protection. Inadequate clearances.
Your hearth protection needs to extend 18" all the way around the stove. There needs to be 36" from the stove to any combustible materials in any direction.Would you please be a little less vague?
So, the dog beds are the problem? Please elaborate.Your hearth protection needs to extend 18" all the way around the stove. There needs to be 36" from the stove to any combustible materials in any direction.
Yes. What type of floor is the stove on?So, the dog beds are the problem? Please elaborate.
Ok in that case move combustibles away and make sure there is 36" in every direction to any combustible walls. What is under the slate?Cement and slate
Cement.. btw, I think the dogs are combustible, but they’re not moving… 😂🐶Ok in that case move combustibles away and make sure there is 36" in every direction to any combustible walls. What is under the slate?
As I said if you want more heat remove the covers and get direct flame on the pan. But is that actually a working stove? It looks like a salesman sample.So, does anyone please have the answer to my original question about those round removable things? Do I take it off, put a pan on it and hope it doesn’t smoke?
When the chimney is hot, the rising gases cause a low pressure area in chimney, pipe and open and stove. This allows the higher atmospheric air pressure to push into the stove intake feeding the fire oxygen. This is what makes the stove work. When you remove a lid, the higher air pressure pushes in, so smoke will not come out. If burning wood, the air leaking in makes the fire burn stronger.So, does anyone please have the answer to my original question about those round removable things? Do I take it off, put a pan on it and hope it doesn’t smoke?
This is the top. It has been repainted, but nothing else. What does oiling do and how do I do it? The other stove was just an example I pulled from the internet.When the chimney is hot, the rising gases cause a low pressure area in chimney, pipe and open and stove. This allows the higher atmospheric air pressure to push into the stove intake feeding the fire oxygen. This is what makes the stove work. When you remove a lid, the higher air pressure pushes in, so smoke will not come out. If burning wood, the air leaking in makes the fire burn stronger.
Cooking on stove top, the highest heat is over firebox. You slide pots and pans to the area with the heat you want. If you want to cook faster, like searing meat, or boiling water, you remove a lid over the fire with a lifter tool. Set pan or kettle over hole for direct flame contact. You will learn to keep food moving, like wok cooking since it will get very hot quickly. It will cook just as fast as a gas stove top.
Some antique cast iron pans have a ring around the edge that seals to the stove top. This is called a smoke ring. You don’t need that type, but they seal better keeping the fire at the desired setting using the air intake.
Do you oil the top and lids? Has the stove been painted, or is it original stove black polished frequently? You treat the top differently than the rest of the stove.
Do you have a Queen stove, or is the one shown in pic what you are trying to use?? You are not picturing a working stove. We need to know what stove your question is in reference to, since many are operated differently.
![[Hearth.com] burner covers [Hearth.com] burner covers](https://www.hearth.com/talk/data/attachments/294/294848-0ea82e11633b336860ad6cd3f4465da3.jpg?hash=q50aA8zyk3)
The Queen stove pic I pulled from the internet for illustration. The shield is away from the wall at the proper distance.As I said if you want more heat remove the covers and get direct flame on the pan. But is that actually a working stove? It looks like a salesman sample.
How far is it from the stove to the edge of the shield behind it? Is the shield spaced off the wall?
What distance is it? What distance is the stove from the wall when measured from the corner to the wall just past the shield?The Queen stove pic I pulled from the internet for illustration. The shield is away from the wall at the proper distance.
If the stove top had been painted, and you want to continue with a painted top, remove any rust with a wire wheel in drill, sandpaper or steel wool until cleaned down to bare cast iron where rusted. (The small area in pic can be cleaned with steel wool) Only be concerned about the outside. Paint with high temperature paint and fire when dry for final cure.This is the top. It has been repainted, but nothing else. What does oiling do and how do I do it? The other stove was just an example I pulled from the internet.
The shield is a foot from the wall and a foot from the stove.The Queen stove pic I pulled from the internet for illustration. The shield is away from the wall at the proper distance.
