so, add $150 or so for a new burnpot too.......and a gasket while we're at it......the old p38 burnpot wouldn't allow for the igniter either...slot too narrow, had to use an Accentra FS burnpot to make it "easy". I agree, not worth the expense, but a fun project anywho.
control board, igniter, ESP, burnpot and flame guide and you take a P38 and trun it into a P43I think I still have a couple of those kits, but originally they were made to convert p61's to p61-a's......and it was was never really easy to do (the burnpot wasnt drilled and tapped for it, etc). I would think it would be easier these days to convert a new p38 to autoignite, but you would need a new circuitboard, which would fit on the standoffs......as for converting an "old" p38, would be more complicated, but do-able, just dont think it would be worth the expense to make it autoignite.....have to add the parts up, but you'd need and igniter, wiring harness, circuitboard (and likely more)......thats around $400 for the parts alone, let alone labor......unless you do it yourself.....interesting project.....
pretty hard to argue with those numbers! youre missing the burnpot gasket tho, and shouldnt need a new ESP probe......just a dipswitch setting on the new board needs changed (switch 5, I beleive)Sounds good but still a tad expensive.
(broken link removed to http://www.stove-parts-unlimited.com/Harman_Circuit_Board_Control_Panel_Most_Models_p/1-00-05886.htm)
$210.00 - Control Board
http://www.stove-parts-unlimited.com/Harman_Pellet_Stove_Flame_Guide_p/3-00-08534.htm
$33.00 - Flame Guide
(broken link removed to http://www.stove-parts-unlimited.com/Harman_Thermister_Probe_ESP_Probe_Red_Wires_p/3-20-00844.htm)
$56.00 - ESP Probe
(broken link removed to http://www.stove-parts-unlimited.com/Harman_Accentra_FS_Burn_Pot_Weldment_p/1-10-08736.htm)
$150.00 - Burn Pot
(broken link removed to http://www.stove-parts-unlimited.com/Harman_Igniter_Cradle_Kit_1_Set_p/1-00-06620.htm)
$25.00 - Ignitor Cradle Kit
(broken link removed)
$86.00 - Igniter
(broken link removed to http://www.stove-parts-unlimited.com/Harman_P43_P61A_and_P68_Circuit_Board_Plate_p/1-10-08327.htm)
$35.00 - Knob Panel
$43.33 - Harman Stove wire harness
$638.33 -- Is that everything?
MSRP is $410 more for the P-43 so not so bad for the upgrade parts!
P-43 price $2829
P-38 plus price $2419
yea, not arguing, just dont think converting is cost-prohibitive, thats all......Hello
Ok, took out the ESP probe. I can cut my own Lytherm burn pot gasket for $4 so $586.33 for everything!
(broken link removed to http://www.stove-parts-unlimited.com/Harman_Circuit_Board_Control_Panel_Most_Models_p/1-00-05886.htm)$210.00 - Control Board$33.00 - Flame Guide(broken link removed to http://www.stove-parts-unlimited.com/Harman_Accentra_FS_Burn_Pot_Weldment_p/1-10-08736.htm)$150.00 - Burn Pot(broken link removed to http://www.stove-parts-unlimited.com/Harman_Igniter_Cradle_Kit_1_Set_p/1-00-06620.htm)$25.00 - Ignitor Cradle Kit(broken link removed)$86.00 - Igniter(broken link removed to http://www.stove-parts-unlimited.com/Harman_P43_P61A_and_P68_Circuit_Board_Plate_p/1-10-08327.htm)$35.00 - Knob Panel(broken link removed)$43.33 - Harman Stove wire harness$582.33 -- MSRP is $410 more for the P-43 so not so bad for the upgrade parts!P-43 price $2829P-38 plus price $2419
