Hello,
Bought my first wood stove and went straight for the biggest and baddest, or thereabouts.
Trying to heat a 3000sqft home, built in late 1800s with some remodeling and additions in the last 50 years. Flue is 25 or 30 feet straight up through chimney (lined pipe through chimney).
My issue is that this thing has a large firebox, and an overheat surface temperature of 800 according the the manual. However, with a hot bed of coals and only two logs, the secondary air will let it get up over 800. I can choke off the secondary air to cool it down, but then it's smoking out the stack.
The other day I really loaded it up and the surface temperature got so hot it burned the paint off my thermometer. Judging by where the needle went, it must've been 1200 or 1300. Despite this, the thermometer I have on the stove pipe was only at 450 at this time. The stove pipe sits at around 250 if the stove top is around 700 or 800. No parts of the stove were glowing red or anything, but I'm just not sure what to think. The thing wants to run hot.
So what am I supposed to do? Only throw a couple logs in at a time and keep refueling it every 90 minutes or so?
Edit: I should add that all these temps are with the primary air closed off. When the wood is gassing, it'll just rip and rip and rip.
![[Hearth.com] Can't Keep Heco 520 Cool [Hearth.com] Can't Keep Heco 520 Cool](https://www.hearth.com/talk/data/attachments/294/294212-cc5f7f5b3c02c47715d32582e1263962.jpg?hash=IRvmDZuugO)
![[Hearth.com] Can't Keep Heco 520 Cool [Hearth.com] Can't Keep Heco 520 Cool](https://www.hearth.com/talk/data/attachments/294/294213-dd4fcf1c5a57ab044162774e2ed6cc83.jpg?hash=-KUDaGWcMI)
