I want to convert a wood burning fireplace to gas (propane). I heard I may need ceramic glass. Do I need to change the glass in my doors to ceramic?
With a gas fireplace insert, the glass doors would be removed as unnecessary, since the insert provides a view of the fire.
All of the ones I sold requires the glass doors be open. I actually viewed the remote as a detriment because it increased the chance of damaging the equipment by running it with the doors closed.So your plan is to install a set of gas logs.
Since your main desire is for a decorative flame effect, that should be fine.
And your glass doors will be useful in reducing the heat loss up the chimney, and perhaps the loss of cool air conditioned air during the cooling season.
You can have remote control of the burner flame installed with thye gas logs if you wish. This would save you from opening the glass doors and squatting down by the gas valve to turn it on and off.
You can ask about the added cost for that when you buy the logs and installation service. Should be around $100.
Thanks for all the good information. The current fireplace has an outside air kit with two 4" diameter intake conduits, so I don't think combustion will be a problem.
