350* is within tolerance for a good running gasser. My son's Econoburn will run between 280-350 depending on circumstances. The other kid with the Garn 2000 averages around 250-300 through a burn.
hoogie said:split it small spend 3x longer runnin the splitter and waistin gas at 3.60 a gallon, then stack it and then in cold or rainy weather lug it down stairs sweep up what mess ya made, miz well lug your ashes up the stairs while your down there to make it worth your while sweep again because there was no forthought on taking the ashes up...lol and make dang sure your stars are aligned so ya might have all your tweeking right on the inside model to maker run good. from what i see a lot less time involed in the out side gasser....but there again just my 2 cents worth...i'm not sure BTUs has ever said a good thing about anything thats outdoors burnin wood...course there again if i had to pay for wood or even have to go find it...it might be a different story...i just wake up and its in the yard drop off...lol
martyinmi said:With all the respect that's due to you,Scott,"the upper echelon of factuality"? Really? 600-800* stack temperatures "on a typical OWB of any kind"? I will throw the proverbial ball back in your court. You need to provide information from an accredited independent test lab that details average stack temperatures from any major OWB manufacturer in the "600-800*" degree range for an 8(eight) hour burn. Good luck with that one!
I'm sure that you will be able to provide accurate statistics from an accredited agency that quantify the average lifespan of the typical OWB that "sits outside rusting and rotting and returns a lifespan of 6-8 years" is actually 6-8 years.
Scott,
You, Heaterman, and myself are on the same page where our intentions are concerned. The way we relay our message to others needs not be offensive. We will never convince persons who are considering heating their homes with a renewable resource that our way is better if we belittle their monetarily based decisions. You appear to be an intelligent individual, and I'm sure you can comprehend the logistics involved with my reply's to some posts here.
We are all in this together-so let's all keep that in mind.
This is probably getting too far away from the OP, but I can't resist asking about what you said about turning off the heat all day - do you mean all day EVERY day? The reason I'm asking is that we frequently shut down our gasser during the day, but only on days when either solar gain will heat the house, or the outside temp is high enough to minimize heat loss. Although there have been many days when our boiler is down most of the day, if we tried to shut down on a cold cloudy day, it would get cold inside in a hurry (lots of glass is a double-edged sword). And, because there isn't any surplus emitter capacity in our house, it takes quite a bit of time to bring it back up. So, if your heat is really off every day; do you have great insulation/little glass, over-sized emitters (to bring it back up quickly), or something else about your place that makes it easy to reheat? And, just a comment about your 15% ash and burning technique - it doesn't get any better, and I would have no problem being your next door neighboor ;-PJrCRXHF said:.... i turn off the heat when i leave for work and start a fire when i get home and burn all night.
...... I know i am not going to get as much heat out of my classic boiler as a gasser but cost and space made the call for me. So far all i have been burning is 15% ash most of the splits are 6" across or smaller i have not loaded more then 1/2 full yet. .......
