Installing a pellet stove in my basement, and the window/door locations are killing me. I can't achieve 4 feet clearance from doors and windows that open, but the manual says that reduces to 18 inches if using cold air return venting. The manual also says cold air return vents must not exceed 4 feet in length, which seemingly rules out a basement floor application ( 4 feet is below grade). 2 inch pipe.
My question - does going to 7 or 8 feet, from stove to vent end, not "work"? What am I pushing by doing 8 vs 4? Safety? Efficiency?
The stove pipe would be between my front door and a window, neither which will remain open if the stove is operating. I'm not one to open windows if the heat is on. It would be 30 inches from the window and 42 from the door.
Second question - if the vent length is a real constraint, can i just live with the vent being 2.5 and 3.5 feet from openings, vs the stated 4 feet, and dispense with the cold air return? IOW, which is worse - the 8 foot vent pipe or the closeness to openings?
