Confused obout heat settings Harmin Invincible RS
Mudmixer
6
PA
I am not sure about heat settings for my stove. I understand the pellet feed dial. Also have 2 other dials. Smaller dial says room temp on top low to high. Bottom of dial says stove temp low to high. I understand the room or stove temp difference. What I am not sure about is also have larger dial outside numbers 50 to 90 I guess for room temp. Inside numbers 1 to 7, I guess for stove temp. Is the smaller dial just for blower speed. Cannot understand why there are 2 temp dials.
Thank You:
Terry
Thank You:
Terry
The Low & High positions are for the distribution blower. The temperature settings are for running the unit on Room Temperature. The ESP will try to satisfy the setting like a thermostat. The numbers on the dial tells the unit how much time the auger should run each time it feeds when the Stove Temp setting is used.
Thank you, I understand numbers on feed dial questioning why there are 2 temp dials unless the smaller dial is just for distribution blower, why have 2 settings on this for room and stove? Hope I am explaining this correctly.
The 2 sets of #'s on the same knob correspond to the respective burn mode you're using as determined by the other knob (this knob being the one that determines burn mode, distribution fan speed, and whether the stove is set to on or off.)
