I have an Enviro Milan. It seems the flame height changes quite a bit and I'm curious if this is normal. The flame will touch the heat exchanger and then slowly die down until its hidden in the burn pot. Then it slowly builds back up again. These cycles take between 2 to 5 minutes depending on the heat setting but they occur constantly. I thought the stove was burning through the pellets too fast so I have the damper nearly closed and I also increased the feed rate and trimmed down the combustion fan but it still cycles.
Any suggestions? Thanks.
