I’m new to wood burning, just installed a wood stove this year and I love it.  I would like to install a second stove in hopes of heating my entire house with wood (two stories about 3500 sq ft).  The new stove would go in my insulated basement at the opposite end of the house from where my current stove sits on the main floor.  To do this I need to add a chimney so I am thinking I could build a square chase that runs straight from the basement to the attic and install a Duravent class A chimney in this chaseway.  In addition, I would like to construct an air shaft right next to the chimney chase.  The chase would measure about 16" square and the air shaft would be about 16 x 20 inches.  I am thinking I could use a fan in the air shaft to move warm air from the basement up to two second floor bedrooms where the airshaft would terminate.  The cold air returns for my second floor heat pump will be located in these two bedrooms so I’m thinking I could just run the heat pump's blower fan on low to circulate this air around the second floor.
In the end, I'd like to use as little fossil fuel as possible to heat my house. I've considered other alternatives but the wood stove seems to be the most practical …
GeoThermal heatpump - $$$
Wood Furnace - This is a possibility but they appear to be less efficient then a wood stove and emit more pollution. Also, a furnace is not “pretty” like a nice cast iron wood stove.
Pellet Stove or furnace – I’d have to buy pellets but I can get wood for free minus my labor (which I enjoy).
Outside Wood Boiler - Too inefficient and too smoky.
Gasification Wood Boiler and thermal storage tank - I must admit, I am very attracted to this type of system but it is very expensive. If I lived further north it might make more economic sense for me but the fact is that Maryland winters aren’t typically very cold. The big advantage of this system is its ability to store heat for latter use and also the fact that it can provide domestic hot water. Considering the minimum $10K extra a system like this would cost, it’s kind of hard to justify the $. However, if I factor in the price of a solar hot water system to the price of the 2nd woodstove option then the price difference for the gasification boiler doesn’t look as drastic. This could still be an option.
Assuming I opt for the second wood stove …
1) How would a chimney chase be constructed? Is framing lumber and drywall appropriate or must it be shielded in any way? Duravent specs just show that there must be a 2 inch air gap between the chimney and any combustible surface. I could install the chimney outside the house but I know it will perform better inside the house envelope and the finished result will look nicer.
2) Are there any safety concerns related to the airshaft – fire codes, that sort of thing? And, as with the chase, is framing lumber and drywall appropriate?
3) Any special issues with a tall chimney? This one would be somewhere around 30 feet or more by the time I get from the basement to two feet above my roof peak. Is there such thing as too much draft?
Before I would start on this project I will verify everything is compliant with my local code. I just want to run a sanity check to see what I am overlooking. Thanks to everyone.
