Is this a typical DIY job or one best left to the pro's. Last time I had my chimney sweeped the guy went to the top and pushed the brush down with the rods a few times, came in and scraped around the firebox and vacuumed it all up and was done. He was in such a rush I question if he even swept it enough, not to mention he did a not show on me 2 or 3 times in a row and the time I wasted waiting for him I could have cleaned the thing 5 times over. He had all the credentials, memberships to the chimney sweep association, etc. I was thinking of buying the brush and rods and doing the job myself. Some seasons I burn 10-20 times, other times I may burn less than 5 times.
I have a traditional fireplace with a terracotta flue. The chimney has 2 separate flue's, one for the fireplace, and one for the furnace. My roof isn't too steep so I can get up there no problem with the brush and rods, and I'm not afraid of heights so that isn't an issue. Is this something I can easily do and know its done right, and not have to worry?
I don't have a clean out on my chimney so all the grime will simply fall into the fire box. My plan is to put a light in the bottom so I can see it when I look down the top, tape off the glass door, and then go to the top and brush it until it all looks clean. Then I would plan to go to the fireplace opening and scrape the fire box, and anything around the flue door and whatever I can reach in the chimney from the bottom.
For a vacuum I have a Rigid Wet/Dry vac and my filter said it was suitable for ash, so i'd just vacuum it all up at the end.
Good plan or should I just deal with the pros?
