I have been running my system for about 6 months now and have had the same issue since day one. If I start from cold I have about 12 psi in the system. If I charge my 1000 gallons of storage up to full I can be as high as 28psi. I have never blown the prv but have avoided fully charging my tanks because of this.
I think I have about 1100 gallons total in my system and have an Amtrol sx160 in the garage and a smaller 30 in the house.
I stopped by a plumbing wholesaler this week and inquired about pricing for a new expansion tank. The guy at the counter who claims to have worked in hvac for 25 years says the problem is probably not my expansion volume but rather that my piping is too small. First time I have heard of this. I have 1 1/4 copper running from my boiler to my storage and then 1 inch running to the manifold in the house. 3/4 inch pex to all my rads. My Alpha pump is only running at 1-2 gallons per minute to supply my rads and the house is heated fine.
If I only get higher pressure as my storage is heating up and then the pressure drops when it cools, how could it have anything to do with pipe sizing? He also said I should never fill my system with well water, only city water as my well water will clog the pipes so maybe that is my problem. I hardly think so since I have had the same issue since the first day.
Without getting into all the calculations, does it sound like I just need more expansion or does this guy have a point?
