Planning to take down an old metal thru the attic and replace with new interior masonry. New one will run up to a cathedral ceiling eliminating need to go through attic. Will be block with a fake brick covering for appearance. Seriously looking at SS liner. Anyways, came upon interesting article which said that in masonry, you don't have the insulation present that most metal chimneys contain and that the entire masonry structure acts like a "heat sink." Made me wonder if the flue temp stays as hot, which is desirable to keep creosote down. One more question, if the block is properly installed using the right mortar should I be worried about any deterioration above roof over next 10 years? Also would it hurt/help if the above roof section is also covered with a brick like facing? Thank you for any ideas.
ore, et al succeed in their version of "cap & steal". ;-)
