Pulled the carb diaphragm off and there was tons of crud and such in there. Looks like the main issue has been found. Gonna do a mineral spirits soak and then rebuild when the kit arrives. Hopefully gets the job done.
So got the carb fully rebuilt. New everything including removing and cleaning under the welsh plugs. She fires right up. Only problem now is carb tuning. It runs at full throttle but seems like it is missing a little power. When it drops to idle she shuts off. I can raise the idle but it sounds like the idle is good. Compression is great - saw is very little used. Thinking its a mixture issue. I put the screws back to original settings but they were most likely played with by the previous owner to get it started. Finally, if you point it down it shuts right off. Any other direction its OK but straight down will shut it off. The shut off switch is loose and keeps shutting it off - will disconnect the switch tomorrow and I think that may alleviate the problem where it shuts off when pointed down. But now, how do I adjust the carb properly so it has a little more top end and comfortably idles.
L screw is more difficult and more critical. Just try to adjust for maximum rpm and then turn screw out 1/8 turn at a time until rpm drops and engine sounds like it is slightly flooding (which it will be)The carb screws did not have any restrictions. I dont really know what four stroking sounds like. Could you say I should adjust the H screw to make max RPM? The L screw I understand perfectly from your description, thank you.
Okay, that's probably too far out (too rich) for both screws. There's no fixed number of turns out that you should use; it varies with temperature, elevation, the particular fuel mixture you use, etc. Generally after a carb rebuild you'd start with both mixture screws one turn out, though the recommended initial setting varies +/- a quarter turn depending on the saw model. Those won't be the final positions, but it should be close enough to get it started.
What you want to do is to set the idle mixture first, then the high speed mixture. Adjust the idle SPEED screw so that the chain is just barely moving. Then adjust the idle MIXTURE screw until the saw idles smoothly, doesn't hesitate when you grab the throttle (which would be too lean) or gradually flood and stall when you let it idle for a longer period of time or tip the saw nose-down. Adjust the idle speed screw to the point where the chain doesn't move at idle.
High-speed adjustment comes next, and I don't have time at the moment to describe that. Will follow up later.
WOW! Thank you! That is precise and what I needed! When you say idle mixture screw you mean the "L" screw?
