. . . if stoves put a max of 700 to 800 degree heat levels up the stack and the SS flue pipe is cleaned every year, why would 2100 degree rated pipe or even 1700 degree rated pipe be required? Can stoves reach 1700 or 2100 degree temps?
Also, if it's double wall pipe, is the 2" gap better filled with insulation or left open so the heat can be carried away to the top of the chimney. It would seem each would have its advantages.
continuing to study . . . !
is when in doubt, you will never regret insulating the liner. Another option is to remove the inner pipe or the entire chimney, put a T in the fireplace and run a Class A packed pipe chimney (chimney typically used for woodstoves) through that space. There is "air-cooled" pipe with a 2100* rating, you will find many different opinions about which is better, packed or air-cooled; however most ZC fireplaces are not installed with a chimney rated to connect a freestanding woodstove to. A local hearth shop or chimney sweep may be able to assist you.
