Well I lit the first fire in my EKO 40 (it’s in an out building, no storage with force air and side arm) Friday night. So far I would say things have gone well. I have some observations and questions.
Getting the air out was a pain
but that is now in the past.
I have read about oiling the door gaskets. That leads to three questions. What do you folks use for oil? How often do you oil the gaskets? How much do you use?
The Chimney flapper likes to, stick sometimes worse the others. I read the thread on the a few days back, does anyone have any updates that help this problem?
Smoke cannot figure out if it wants to flow out the door when I load it or go up the chimney. I have 9 feet of Chimney. I’m just looking for suggestions.
9 hours is the most burn time I’ve gotten so far but it seems to be getting better.
The gasification is working well when I reload it takes right off. At least I think it is gasification.
I run my blower fan on a T-stat from the run switch of my oil furnace T-stat. I was thinking about putting in a cheap (snap disc $16) temperature switch in the T-Stat line so the fan does not run if I run out of wood. I was planning to just strap it to a fitting. Has anyone done this and has it worked?
I also plan on putting a remote read thermometer in the house. What are your opinions on the value of this?
I would also like to thank everyone on this site. I have read it much more than I posted. So many of you have been so much help without even knowing it I really appreciate it.
