Model 25 (installed 2022) operation question?
Wood type: Mainly split Maple, length: 16 inches long; moisture 11-15% / seasoned a minimum of 2-years (under cover).
Model 25 adjustments: Primary air: 10mm, Secondary air: 3 turns CCW, fan opening 50%, chimney draft 0.06 IWC.
300 gallons of storage; warm floor heating system.
I start up the boiler per page 17 of the owner's manual. Gasification works properly; upper door has no creosote (see image).
When operating normally, it has a powerful gasification flame and the distinctive rumble inside the firebox.
Issue:
I can tell when the "anomally" has started...even though the combuster fan is operating and it has plenty of fuel, the boiler water temp starts to decline (I have a camera in the house so I can remotely monitor the boiler Controller; also, I will see light blue smoke coming from the chimney.)
If left long enough, the Controller will time-out then display "FUEL". In the pic below, I have other sensors that display the water temp leaving the boiler (top left) and returning to the boiler (top right). This "anomally" continues to repeat even though the boiler is at operating temp. Many times last season, my first trip to the boiler each day would find plenty of wood remaining, but all the coals gone and FUEL is there to greet me.
I stir the firewood around then start the boiler again. This situation happens again and again and again and... On any given day, I will have to go to the boiler 10-15 times; today I started the boiler at noon, it is now 3 pm... so far, I have had to go to the boiler 4 times in 3 hours to address the "FUEL" message! I have tried everything I can think of (smaller splits, cut wood to 8" length, change Controller settings, etc..) It does get old!
Any suggestions on how to greatly reduce my trips to the boiler? I don't recall my first Model 25 having this issue (or at least this severe.)
PS: Just this afternoon, I reduced the combustor fan speed to 70% (another attempt to solve this issue)
Regards, JT
![[Hearth.com] Eko Model 25 Gasification Issue [Hearth.com] Eko Model 25 Gasification Issue](https://www.hearth.com/talk/data/attachments/317/317796-d369be6e956b601c8a4deda4e2818f94.jpg?hash=r8qG8FAseH)
Issue:
Regards, JT
![[Hearth.com] Eko Model 25 Gasification Issue [Hearth.com] Eko Model 25 Gasification Issue](https://www.hearth.com/talk/data/attachments/317/317794-89369eefb6de4fa7adfec87787beafad.jpg?hash=4tTaStbT4g)
![[Hearth.com] Eko Model 25 Gasification Issue [Hearth.com] Eko Model 25 Gasification Issue](https://www.hearth.com/talk/data/attachments/317/317795-1f4f8b531a0a0761f53bb295f9742128.jpg?hash=4uDrK0pHjF)
