Electric Solar water heater element in my water storage tank
Splitmonster
34
Tolland. Ct
I toying with the idea of putting a few solar panels to the roof and adding a heating element to my 500 gallon water tank that I use with my Vigas 40. Has anyone done this yet?
Reactions: hobbyheater
If you mean just directly wiring the DC output of the panels to the heating element, it should work to give you a few extra BTUs as long as the wattages are matched reasonably enough. Make sure you have some sort of a high limit hooked up and ideally a low water cutoff too.
Many people who "have solar panels" are referring to a grid tied system, and if that's what you're doing you would get many more BTUs per watt by running a heat pump.
You may not have the right voltage if you get a 220VAC heating element. And if there is such thing as a DC heating element could be many amps.
Sure the heating element won't put out it's rated power, it will just consume whatever current the solar panels can give it. Which is why it needs to be rated high enough to not add too much resistance to the circuit and not go over its rated power when the solar panels hit their peak output.
A heating element is just a piece of resistive wire so it doesn't care if it gets AC or DC. However you may have to worry a little more about galvanic effects with DC if it's operating in a moist environment.
Vsquared/r = the power so it's not going to put out very much power without the right voltage. I never thought about the galvanic effect with DC. That could cause more problems than its worth.
You'll generally get maximum power when the load resistance is approximately equal to the source resistance which is the solar panels' internal resistance. Voltage will rise and drop with solar input, as will the heater's output power.
So you set up strings in series/parallel to match the load. Or you can place multiple heaters in series or parallel to match your solar string, either approach would work.
So what do you think. Is it worth looking into it? I don't think i want to go full solar panel array for electric but possibly one or two panels and not grid tied at all.
