I have a Trane heat pump furnace that has an emergency backup heat option that uses propane gas. This is run off a Trane XT500c thermostat. I also have a Classic Bay 1200 free standing pellet heater that runs off a Honeywell Lux 110 thermostat. When it gets too cold for the heat pump to keep up (around 32 degrees) we usually turn on the pellet stove (since this is the cheaper option than the emergency heat burning propane gas). But having the pellet heater on all the time is not cheaper than the heat pump only working. Here is what I would like to do...
I would like the heat pump to be the main heat source. When it can't keep up I would like the pellet stove to assist automatically. The two ways I can see this happen are:
1. Use the emergency signal from the Trane thermostat to control the pellet stove instead of the propane heater. I believe the signal from the Trane thermostat is on the X2 wire. Can I disconnect this wire and hook it to the thermostat wire going to the pellet stove? OR
2. Can i disconnect the emergency wire from the Trane thermostat (leaving it disconnected) and set the Lux thermostat for the pellet so that it comes on automatically when the heat pump can't keep up?
I am not very informed on how heat pumps work. I read on another site that besides calling for emergency assistance (via propane heaters) the emergency wire also is used for some kind of defrosting of the condensor unit? If I disconnect this wire will this harm my condensor?
The wire colors on the Trane are as follows:
Terminal - Wire color
B ---------- Blue
R ---------- Red
W ---------- White
Y1 ---------- Light Green
X2 ---------- Light Blue
O ---------- Red with Black stripe
G ---------- Green
The wire colors on the Honeywell Lux 110 for the pellet stove are both white (since I believe this is a simple switch connection type).
Also is there a way for the blower fan on the furnace to automatically come on while the pellet heater is functioning? I thought this might help circulate the warm air, or would this simply be pushing cold air out of the basement through the house?
Any assistance or other ideas would be appreciated. Thanks
Mac
B ---------- Blue
R ---------- Red
W ---------- White
G ---------- Green
Mac
