Empyre Elite II 200 gasification boiler FAN HELP PLEASE
Roundgunner
360
Rural CT
I am still fixing and repairing my discontinued PRO-FAB Empyre. I have done a lot of things and will answer anyone’s questions if I can. I can’t be the only one out there limping one of these along with no factory help.
I have replaced the fan a couple times. Last February I got one rated at 150 CFM. It got me thru the rest of the heating season and heated the pool now and again thru that season but it never seems to get the secondary burn chamber roaring like it should. Sometimes it seems like it will never get enough air to ignite the lower chamber. It has a hard time even keeping the flapper valve open so I’m pretty sure it is not giving me 150 CFM
I bought this fan rated for 196 CFM. When I plugged it in on the bench it really blew air!
I don’t know much about electronics but I wonder if these 3 leads can be used to slow it down if I think it is getting too much air. If so is there a simple way to rig it without buying a speed control switch?
voltage: 110V /60HZ; Input Current: 1.10A; Input Power: 120W
Speed: 2600r/min; Air Volume: 196CFM (5.5m³/min)
Static Pressure: 350Pa; Noise: 72db(A)
Capa-Citance: 8.0/500μF/V; Weight: 2.5kg (5.5lb)
This fan can be widely used in extruder heat dissipation, kitchen equipment, electronic equipment, duct ventilation, aeration model, purification equipment, telecommunications and other fields.
[Hearth.com] Empyre Elite II 200 gasification boiler FAN HELP PLEASE [Hearth.com] Empyre Elite II 200 gasification boiler FAN HELP PLEASE [Hearth.com] Empyre Elite II 200 gasification boiler FAN HELP PLEASE
It doesn't look like it to me...why not buy a speed switch...one of those cheap router speed controls would work well...plug n play.
Amazon product ASIN B07T9BLJ7L
I'm not against buying a speed controller but I have no idea of what to get. I am concerned that it could blow too much air and get my weakened boiler too excited.
Do you have any suggestions for a controller? I will look on Amazon to see if I can learn anything and search this forum.
Thanks for your suggestion.
Amazon product ASIN B009Z147POThe pressure the motor produces is just as important as the CFM . This motor is an example it needs 13 amps .
Another thing I don't know how to read, but I understand the need. I will try to find the info on the blower I got in February but I know it sometimes doesn't have the pressure to open the flapper plate. It was supposed to be a replacement for the discontinued replacement of the Pro-Fab. 150cfm pretty sure.
I checked to make sure the flapper was clean and free. when heating the pool the boiler never goes to idle, With that (FEB) fan it will not keep the water hot, I have to choke the pool side of the heat exchanger flow with valving.
At 100% on the speed control, it will only blow the same amount as having the bower turned on the way it is now...then less as you turn the speed control down...it will not overdrive the blower.
Is this the kind of controller I'm looking for or should I look for something that this new blower just plugs into and forget about the leads coming out of the blower?
Amazon product ASIN B08HDDRBTG
You probably could use that...but why not make it simple and buy one like I linked earlier?
You see no link in post #2?
How about in Hobbyheaters post? There is one there too...
Reactions: Roundgunner
Try this one...
I can see this one. I was thinking maybe I had a setting set wrong.
Thanks, I will look at this in the morning, my eyes are so tired I cant even see the clock.
Much like you there was no support from Kerr for my Jetstream so I was on my own.
When my original blower ( a vacuum motor) packed up, I ended up mounting the motor remotely and piping the blower air to the boiler.
I ended up putting a gate valve in the pipe to dump excess air. ( not all motors are equal in pressure and flow )
Reactions: brenndatomu
I got this in and I'm running it at medium speed. It seems so much better than the last fan. I'm having small water leaks but it's burning! My buddy welded on it for hours the other day but it is a loosing battle.
Funny thing, my wife was absolutely set on not replacing this boiler but is changing her mind watching our friends buying oil at over $5.00
I'm going to start looking at Central Boiler. Any thoughts?
I would really expand your list of company's to look at...
Reactions: sloeffle
I'm probably too late to the party, but ours has done the same every few years. I'm thinking the fan model/speed may not be your problem at all and it's your intake air passages need a good cleaning. When you pull off the fan, there's a sort of birdhouse sized space that gets pretty full of gunk. There's often a blob of fossilized ooze of combustion tar/slime and a few handfuls of gravel-like slag/biochar. Once you get that pried loose and removed, if you feel around inside, you'll feel the openings of small passages sort of hidden around the interior of this box. I use screwdrivers, heavy wire, etc. to bust thru any crap plugging them up. If I remember right, there's one vertical to the top of the combustion chamber) and one horizontal to the manifold. (maybe a 3rd to lower combustion?) Pulling up the bricks along the left side will let you clear out ashes and crap on that end.
