Howdy folks,
I am troubleshooting an auger timeout error code with the Fahrenheit Endurance 50 furnace.
Here's a run down of what's been confirmed / tried:
Could the blower/limit switch still be the problem, even though I got the error with the hi-limit bypassed? Maybe I should be investigating the auger more since it didn't take to the prime button briefly this morning?
Appreciate any guidance.
- Error will appear seemingly at random, sometimes at start-up even.
- The auger seems to operate fine, as viewed with rear cover removed
- Blower operates
- Hopper was cleaned to ensure no jam
- Hi-limit switch was bypassed and error still occurred
- The assumed culprit due to above was the control board (even emailed with folks at Fahrenheit to confirm).
- Installed new (expensive) control board today. Error immediately shows up.
- I DID notice that when I tried to 'prime' the auger, it didn't want to spin for a bit. But then later in the startup process it started operating fine. FWIW, the startup process is really slow with lots of vacuum pumping (but no vacuum error codes).
- I was able to run the machine on manual mode for a bit with no error, but I HAVE previously gotten the error on manual mode.
- When I tried to operate on thermostat mode (our typical configuration) it errored pretty quickly (the thermo might not have been calling for heat). It has worked before with the thermostat.
