This is a repeat thread with a better post description. I have an Englander pellet stove mfg 7/2012. After starting the stove and coming up to temperature, the blower fan comes on (low speed) to blow the air into the room. The problem is that when trying to adjust the fan speed on the main board, the fan does not change speed up or down. I'm thinking it might be an issue with the board. Not sure if the fan can be bad since it does come on. Otherwise, everything appears to be working properly. Has anyone come across this issue or have any advice? Thanks
