i have an issue with the room air blower not working properly. top and bottom augers both work properly as does the igniter. when the stove reaches the lower running temp, the room air blower starts and stumbles a bit when it first comes on like it is not getting fed constant voltage. while the stove is at operating temp, the room air blower does not sound like it is running smooth like it does with my other identical stove. now the real problem is when i shut the stove down, the room air blower really starts stumbling and it will even run on after the stove is cold to the touch. what could be the problem?
in testing, i plugged the room air blower into the bottom auger contacts on the back of the board and the blower comes on and runs fine and smooth. does this sound like the board needs to be replaced? or just replace parts on the board. i'm very comfortable with working on electronics and soldering and just don't want to start replacing parts on something that can't be fixed lol
edit: i should also note that running the stove in diagnostic mode, everything is working as it should using this diagnostic guide (broken link removed to http://www.heatredefined.com/support/troubleshooting-guide/diagnostic-test-mode)
