I been having low heat issues and been troubleshooting for weeks and still not 100% working. So far I cleaned everything quite good etc heat exchange, both blowers, flu and whole inside even behind plate. I changed upper auger motor and all seals. Originally I was getting low heat form one side and cleaning the bloer helped with that issue and now it seems to be getting hotter and on both sides.
Now it seems like the issue is the pellets seems to not be feeding enough to keep the flame going no matter what setting I keep the heat range setting at. I have the default settings to D 6-4-1. Now if i raise the heat range to 4,5,6,7 the pellets still intermediately can't keep up with the flame. Should I try to set the default to 6-5-1 to test?
I also noticed the upper auger I changed is turning in the opposite direction of the bottom auger bottom auger is turning counter clock wise and top clockwise. does this sound right?
thoughts?
PS pulled motor and reversed it and both turning counter clockwise...(looking from front) and retesting system...
thoughts?
