I've seen and read lots of threads on this and am obviously still confused on the magic buttons .. and when the settings are 'used' by the stove.
Yes, there's the 'mode' selection. Mike at Englander said mine should be run in 'b' mode .. (older unit / 2 augers, etc).
Someone said the magic buttons are only used when the stove is in 'low' mode ... like when feed rate is set to 1 or 2. So ... they really aren't used when the stove is set to say, 9? ...Seems concievable the M3 (Magic 3 ) button settings could be used as a ratio, and the feed setting used as a multiplier ??? If only used in 'low' mode, why do folks tout those numbers when they are 'getting a lot of heat'? (I assumed the latter was because they were running in a 'high' mode ... 5+ on the feed rate).
If the M3 settings are only used in the 'low' feed rate settings ....
1) what does the 1 and 2 do on the feed rate then, as the LFF is a feed rate also? Which one wins?
2) what controls the burn air rate? If you have a poor/dirty/lazy burn, and I'm told I either need a lower feed rate, or more air .. how can I adjust the air, if the M3 #2 doesn't do it?
As soon as I read a post and think I have it figured out ... I realize I don't ... or read another post that counteracts it. LOL
