Englander 30 NCG installation question
Jed Tyrney
6
Wyoming
Howdy Folks,
I just bought an Englander 30 NCG stove. I am going to install it where a woodstove was once installed on top of a tile ledge in a corner. I looked at the clearance to combustibles chart, it is calling for 15" from the corner to the wall. I have it lined up with the existing chimney box in the ceiling and I only have 11" to the wall from the corners of the stove. It is a wood lathe plaster wall so would I need to install some sort of wall protection to keep things from catching fire? Thanks!
Mike should chime in here shortly on this topic. How is the hearth constructed? This stove needs an R = 1.5 hearth insulation too.
Put the stove at the required distance and put an offset in the connector. We had to do this. Be sure the hearth has sufficient insulation too.
Put two 15* elbows in the stove pipe to offset the stove out away from the wall a bit?
Edit: Crap, quick draw mcgraw beat me to it! ;lol
Howdy,
Thanks for the reply. So far what I can tell, it's tiled over a wood frame. We just bought the house not too long ago. Thanks!
Howdy,
if its tiled over a wood frame (no additional protection its probably not going to meet the 1.5R requirement of the unit , would require reworking with additional heat protection to mount a 30
That's something I didn't think about. That might work actually. Does that make the chimney harder to clean?
an offset would make it marginally harder to clean BG could give you a better idea as he has that setup
Sounds like I am going to need to rebuild the whole hearth!
unfortunately it does sound that way. shop online for "micore 300" this is the thinnest and highest R factor material for this type of structure im pretty sure "do it best" carries it in their online store , may be able to find a supplier through "us gypsum" as well
Reactions: PapaDave
Well thanks guys! This is exactly what I needed to know. Thanks for the help! I'll check online and see what I can find.
