I have an older Englander that I bought last season for next to nothing. I bought it untested. The guy said the top auger became noisy and there was no way to lube it. Got it for $250. Did some research on this forum and had some help from Ssycho on getting it going. Took my time and pulled it apart and cleaned everything. The top auger was new but whoever installed it had put it in wrong and the grease fitting was at 12 o'clock and you couldn't lube it. I loosened the collar and turned it to the left and lubed her up and it runs great. I plugged the two large holes in the burn pot and have been running it at 2/9 with great results. The bottom numbers are factory set. I now wake up in the morning to what you see in the photo. Lots of ash build up. The flame isn't lazy it is just that I took the photo with the door open so you can see the pile up. Any suggestions?
