Englander Add-on Setup Questions
cnpeele
7
Virginia
Hello,
I recently bought an Englander 28-3500 for my home. I have the chimney liner installed and got the beast in my house, now I just need to finish hooking it up. I have a couple questions about flue clearances. The manual tells me I need 18" clearances from combustibles. The flue is entering a thimble in the basement, and I have the floor joists to deal with, but also some plumbing. I am doubting PVC falls under "combustibles", but I figured I might need to shield it from heat somehow. I have seen some other installs on here where people use concrete board with a metal sheet to block heat. Would this be necessary for the plumbing? Also, the run to the oil furnace is just under 20 feet. Can/should I use some type of insulated ductwork to preserve heat on the way? Any clearance requirements for this ductwork to combustibles?
BTW, I am located about five miles from Englander Stove Headquarters, if that helps the Englander guys on any advice as far as codes, etc.
PVC is a combustible material. I believe the codes would require an adequate clearance and or shielding.
I did not insulate my ductwork (yet). 20 ft. run on mine also. It is transferring the heat to my main duct fine. Follow the manual. Put a 90* elbow in your main duct or plenum so the air is blowing with the flow from your primary furnace. Pay attention to ductwork clearances from combustibles. If you lose electricity the ductwork can get screaming hot. If installed correctly, the 28-3500 will make a ton of heat. My 2700 sq.ft. house will be 75* on a 0* night with just a moderate size fire. It will take some time to learn how to best control the heat and wood use. Any questions, I will be happy to help if I can.
Good luck
