Hi im not sure if you can help or not, I have a older model pellet stove that is having issues. Its an Englander brand and the top auger is not turning on start up . It is not jammed and will run when bypassing the vacuum switch during test mode. However if I try and start it up while still bypassing the switch it doesnt run. We have replaced both Vacuum switches and hoses and are still having issues
just make sure you unplug before you work on it. that board has line voltage all over it and it bites
