Hey CG..
I'm a Ford guy but I'll see if I can help out.
Not sure if you have a steel or cast stove so I'll keep this generic
Only a few places to lube on the stove.
The agitator chain Few drops of oil.
The left end of the Agitator Rod. High Temp anti-seize.
If you have a clean out "T" the threads on the removable cap. Same Anti-seize.
For the chain any good light machine oil will work (3-1, 30w motor oil, etc)
For the agitator rod and the clean out T. I use Loctite C5-A It came with the stove form Enviro.
For Deep clean.......
Unplug, spread drop cloth, Get tools ready including vac
Remove Vent Pipe at the appliance adapter/clean out "T"
Remove top, sides, and back panel.
Open door
-remove fire box top skirt
-remove agitator rod
-remove fire box liner
-remove fire box
-push up on baffle plate and remove back panel carefully
-lift rear panel shelf (the one with the two access holes) straight up then out
-close door and run the heat exchanger tube scraper in and out a few times.
-brush/vacuum inside of fire area including up around the heat exchanger tubes.
-open ash pan door and remove ash pan.
-clean/vac out ash pan area
-using paper towel clean glass. (I use a damp paper towel dipped in ash to clean)
-wipe dry and apply coat of Ceramic glass cleaner/sealer. I use the Rutland brand.
-wipe that off and you are done cleaning the inside.
Take all removed fire box related item outside for good scraping/chipping session.
-I use a painters 5-1 tool for chipping scraping works well for me.
-Chip/Scrape/Beat the snot out of.... all clinker/scale from fire box liner. Get it clean down to bare metal! Carbon is hard to see sometimes.
-scrape the fire box itself, especially the skirt edges
-scrape the agitator rod clean, especially the ends of the nubs
Replace all fire box "guts" back into the stove
-start with the rear panel and baffle plate
-then the firebox
-then the firebox liner
-then the agitator rod. Apply a smear of Loctite C5-A to the left end of rod
-then the top skirt
At this point you are done inside. Close the glass door and the ash pan door.
Get a beverage.
Now the blowers
On left side is the exhaust blower
-mark connectors and pull apart
-using TORX screwdriver remove blower. Be mindful of gasket. Try to re-use or have spare handy.
-clean/scrape/vac blower plenum area on the stove
-pull off the (orange-ish) silicone vacuum tube and run a paper clip into the hole.
On right side is convection/room air blower
-loosen/remove the bolts holding the blower in place
-While supporting the room blower.....slide it out to the right Be careful not to drop it and bend the vanes.
-Vac up inside of rear portion of stove (loose pellets/dog hair/etc.
I use a compressed air, an old tooth brush, angled scraper, etc to clean the exhaust blower.
A bit of mineral spirits/carbon remover (Seafoam, Berrymans, etc) helps.
blow clean and dry
For the convection/room air blower I use compressed air, CRC electronic cleaner and an old toothbrush.
IIRC neither blower needs lubrication.
Grab a beverage.
Replace the blowers back into stove mindful of connectors
Now clean the vent pipe.
Caution....This part is messy
My install is a 14' straight vertical pipe
I run a 4" dryer vent brush up the pipe while holding a vacuum at the bottom.
I run it up and down in a scrubbing motion until nothing else falls out.
I lubricate the threads of the clean out "T" with a few smears of the Loctite C5-A
Finish up
Re-connect the vent pipe to the stove
Replace the side panels
Replace the top. Ensure the daughter board (controller pad) is firmly connected on its ribbon cable
You should be good to go.
Couple of tips.....
A vacuum adapter tube is handy. It takes a 2"-ish vacuum hose down to 1/2'. To reach into the small nooks and crannys of stove
A very used sponge with a green scrubby side works great at cleaning the glass
A Shop-Vac with HEPA filter keeps the wife happy and dust off the living room furniture
An oil filter wrench works great at unscrewing the Clean out "T" cap if stuck on.
Extensive reading and "SEARCHING" of the Heart.com forum will provide years of knowledge from many great people
Hope I didn't miss anything
Good Luck with stove.
---Nailer---
