I've been chasing trouble with an Enviro M55, and I even had local dealer come out to diagnose. We still don't have it.
M55 (free standing) was running great until one day it did shutdown cycle while still plenty of fuel. Blinked 3 as if it was out of fuel.
For a while it restarted great and then did shutdown after 15 minutes startup. Auger feeding fuel fine. Combustion-Exhaust blower running good. Igniter starting the fuel just fine. Great startup and good burn but then shuts itself down.
This problem sounded exactly like the M55 could not confirm "fire" after startup. So ran test of bypass exhaust temp sensor. But igniter (maybe auger too) was then intermittent. Sometimes when successfully lighting a fire it would shutdown with blinking 4 but other times 3. Other times the igniter and auger would not run, but some vibration to the stove would start igniting (like a loose connection or failing switch?). Made sure stove was clean. Checked connections were secure. No improvement.
Tried bypass of vacuum switch with no luck. Lots of blinking 4.
Had service call from nearby dealer and after a lot of tests (that didn't work) they bypassed the High Temp as a test and got the stove running. They concluded High Temp Limit switch had failed. So we thought the repair was done. A couple hours after leaving the stove started shutting down with blinking 3 OR blinking 4. And now it won't run auger or ignite ... even with the High Temp switch temporarily bypassed it's blinking 4.
Weirdly we started with this stove running great! Hard to imagine more than one sensor / switches failing all at once but we have been chasing this problem in circles and can't identify a (single) fix.
