Enviro Maxx-1 thermostat install
Nenamc Posted By Nenamc, Jan 6, 2019 at 2:12 PM
  1. Nenamc
    Nenamc
    New Member 2.
    NULL
    Jan 6, 2019
    8
    0
    Loc:
    Northern Nevada
    Can anyone help me with how to correctly install a honey well manuel thermostat to the Enviro Maxx-1. I do not know what the dial on the inside of the thermostat needs to be set at....1.5 2? We upgraded from a Quadra fire 1200 and have had nothing but issues with the 1200 and the thermostat. I want to make sure I'm connecting and setting it correctly to the Maxx-1.
  2. Ssyko
    Ssyko
    Minister of Fire 2.
    NULL
    Nov 6, 2017
    2,153
    518
    Loc:
    Lorraine NY
    the manual should tell you exactly how to hook the thermostat to the stove. the thermostat manual should tell you how it it hooked up and how to set. Honeywell makes dozens of tstats. which one did you get?
    Stop hovering to collapse... Click to collapse... Hover to expand... Click to expand...
  3. Nenamc
    Nenamc
    New Member 2.
    NULL
    Jan 6, 2019
    8
    0
    Loc:
    Northern Nevada
    Manual doesn't say what the setting needs to be neither does the thermostat. Not sure what kind of honey well thermostat it is. Threw the box away a couple years ago after I hooked it up to the old pellet stove. I just don't want to hook it up an screw up my Maxx, we just got it. Or is it just better to run the stove in Manuel mode?
    Thank you for your help.
  4. JRemington
    JRemington
    Feeling the Heat 2.
    NULL
    Nov 4, 2017
    404
    68
    Loc:
    Belleville New York
  5. JRemington
    JRemington
    Feeling the Heat 2.
    NULL
    Nov 4, 2017
    404
    68
    Loc:
    Belleville New York
    After you hook up the thermostat you have to start the stove in manual mode. After it finishes start up mode you can either set it to hi low or on off.
  6. JRemington
    JRemington
    Feeling the Heat 2.
    NULL
    Nov 4, 2017
    404
    68
    Loc:
    Belleville New York
  7. Nenamc
    Nenamc
    New Member 2.
    NULL
    Jan 6, 2019
    8
    0
    Loc:
    Northern Nevada
    Yes, 2 wire red and white. I've been reading a lot of threads, the only part of the hole thing is not knowing where to set the dial, 1.5 or 2, I honestly do not understand that part of it.
  8. JRemington
    JRemington
    Feeling the Heat 2.
    NULL
    Nov 4, 2017
    404
    68
    Loc:
    Belleville New York
    After you get the thermostat hooked up put the mode setting on manual and start the stove. After the mode light goes solid set your heat level on one and switch the mode to hi/low. When you turn the thermostat up and it calls for heat your stove will burn on high setting until the thermostat is satisfied. At that time it will go down to setting one until heat is called for again.
  9. JRemington
    JRemington
    Feeling the Heat 2.
    NULL
    Nov 4, 2017
    404
    68
    Loc:
    Belleville New York
    I’m not a big advocate of thermostats. I just set the temperature on what setting I will need for the temperature of the day. That stove you have is a heating machine.
  10. Nenamc
    Nenamc
    New Member 2.
    NULL
    Jan 6, 2019
    8
    0
    Loc:
    Northern Nevada
    Thank you again for your help. Oh man does it heat! I'll decide later if I want to hook up the thermostat. I'm going to keep researching on the Maxx and thermostat's pros' and con's.
  11. JRemington
    JRemington
    Feeling the Heat 2.
    NULL
    Nov 4, 2017
    404
    68
    Loc:
    Belleville New York
    We sell these. They heat. The blower is a little noisy on high.
  12. Nenamc
    Nenamc
    New Member 2.
    NULL
    Jan 6, 2019
    8
    0
    Loc:
    Northern Nevada
    We just installed it 3 days ago.
    Question, I turned it on low made sure the dampener is correct, and it started shutting down after running for 35 minutes. I looked at the panel and the mode light is flashing and the 3rd light on the heat indicater is also flashing. Not sure why. Is this normal? I've not touched anything other than to turn it on. I did not hook up the thermostat to it.
    So many questions!
  13. JRemington
    JRemington
    Feeling the Heat 2.
    NULL
    Nov 4, 2017
    404
    68
    Loc:
    Belleville New York
  14. Nenamc
    Nenamc
    New Member 2.
    NULL
    Jan 6, 2019
    8
    0
    Loc:
    Northern Nevada
    Brand new. It's going to be a learning process, that I understand. I just wish there were some videos on how to correctly run this stove, step by step. It's almost like I cant get the dampener set correctly. I've ran wood stoves before but this takes the cake!
  15. JRemington
    JRemington
    Feeling the Heat 2.
    NULL
    Nov 4, 2017
    404
    68
    Loc:
    Belleville New York
    If you want you can call me and I’ll walk you through how it works.
  16. Nenamc
    Nenamc
    New Member 2.
    NULL
    Jan 6, 2019
    8
    0
    Loc:
    Northern Nevada
    Awesome, thank you so much!
  17. JRemington
    JRemington
    Feeling the Heat 2.
    NULL
    Nov 4, 2017
    404
    68
    Loc:
    Belleville New York
  18. Nenamc
    Nenamc
    New Member 2.
    NULL
    Jan 6, 2019
    8
    0
    Loc:
    Northern Nevada
    So sorry, it took me a day to get back to you. So far after my fiasco of the low setting issue, my husband was able to figure out it was the trim feed. He showed me how to work that. Everything seems to be working great now! And yes this stove will heat you out of the house. Still have not hooked the thermostat to the stove. I'm going to try and hold off on that as long as I can. I want to do some research on what thermostat works the best with the stove. And what setting best works for the stove and my home.
