error code
libirm
138
Long Island, NY
Number four is flashing, below is what the Manuel says below;
6. Light # 4 on Heat output bar flashing.
• Hopper is open, or hopper switch has failed.
• Reset sensor and determine cause. Was it Convection Blower failure or Circuit board control problems?
• The 200 °F (93 °C) high limit temperature sensor has tripped.
How is do I reset the the sensor?
If it's a snap switch type, it'll have a little red button in the center. Just push it in, you might hear a faint click as it resets. If it's tripped, you need to find out why. Make sure the room air blower is working properly, and the unit isn't over firing.
Their english might mean to close the hopper door and make sure the switch is working/adjusted properly.
Thanks Heat.:)
Found the switch...reset it....restarted and it has been working normally over night.
Hopefully it will stay that way for the rest of the season and then we will service it.
Thanks Heat.:)
Glad you got it all figured out. Do you have any of the upgrades installed?
Hello JT
Not yet...have to talk to my dealer this week...
Thanks for asking! Have a great Sunday:)
