The secondary air comes in from the front, below the door. Just FYI...Is that the secondary air inlet?
And when the fan is not running...there is probably not much heating going on. If it weren't for the fact that my fan switch is in the back (original location for the early models) and it is an adjustable switch, I don't think my fan would run as much as it does...and my "no heat" situation would be even worse than it is.Recent observation now that I'm running both tundra's a bit, both with serial #'s in the 1340's. The fan switch takes a lot more heat to run the fan on my 2nd install. So much so that the damper almost has to be open to have the fan come on. Once the furnace has settled into secondary burn with air inlet closed the fan shuts off after a bit and takes a long time to come back on plus the top of the furnace is getting much hotter than my other Tundra.
A quick IR check shows it's taking 20-30F more to get it to turn on. I've ordered a adjustable fan switch to resolve the issue.
)Glad i could help, It did do a really nice job cleaning the inside of the HE. I think i am going to get an 8" poly brush and cut it down a hair so its nice and tight to fit into the center tube. Thanks for the inside "naked tundra" photos. Did you use a steel or poly brush on the inside of the HE? If steel did it scratch the walls?I think I am on to something. I made an adapter so that I could spin my 6" chimney brush with my drill (thanks for the idea @Builderml ) and cleaned the heck outta the HEs last night (killed a fully charged L-ion battery!) I thought I had it spic n span in there until I looked very carefully with a bright light. There is a thin and highly polishedlayer of baked on soot/creosote covering patches in all 3 HEs. It is about as thick as a heavy layer of paint (think old house paint) and to the "untrained" eye, it looks like bare metal. I confirmed it was not metal by hitting it with the torch...yep, it popcorned up like creosote does when heated real hot! This stuff is really hard and the chimney brush will be worn out before it all comes off. Scraping it off with a sharp edge works but is very time consuming and it is hard to reach much of it. I'm gonna wheel my oxy/acetylene torch in tonight and finish burning it off. I thought about spraying it with kerosene and just lighting it... but thought better of doing that, probably make a mini chimney fire
I tried to get pics but the camera just didn't pic up what I was seeing in a way that shows up on the screen, sorry guys, gotta take my word on this one
 I jumped the fan switch out for the remainder of the job...
 I jumped the fan switch out for the remainder of the job... )
Steel, 'cause it was what I had. It just polished the walls like a wire wheel does on steelDid you use a steel or poly brush on the inside of the HE? If steel did it scratch the walls?
 My thought is that I can always add more wood but I can't take it out. Temps below 5F will give her a run for the money.
My thought is that I can always add more wood but I can't take it out. Temps below 5F will give her a run for the money.The damper was open or closed when you were getting 98* at the registers?@brenndatomu, I rarely fill my firebox more than half full. I will call it a "medium fire".My thought is that I can always add more wood but I can't take it out. Temps below 5F will give her a run for the money.
but I have sneaking suspicion that I will be installing a supply plenum before this is all over...
It does make sense, there is a lot of heat radiating off of that top, especially toward the front outlet. I would probably uncover it also if I do a plenum, so it would be the two side and the front outlets open, for a total of 3.One of the contractors I had give me a quote wanted to do this. He claimed I'd be able to extract more heat from the unit. Makes sence but I'm no pro! I'd be really interested if you did this and heard what your results were.
Yep same here, cycles at the end. I was over 9 hrs into the load when I posted that about the "5 on 10 off" thing.Brenn, just to let you know once my fan comes on it stays on the whole burn. None of the 5 on/ 10 off stuff, the only time its does start to cycle is at the end when it just has some coals left.
![[Hearth.com] Everything Drolet Tundra - Heatmax... [Hearth.com] Everything Drolet Tundra - Heatmax...](https://www.hearth.com/talk/data/attachments/169/169852-c9eca3d1be848c6d8bb88ddda6f8f1df.jpg?hash=0nePNkk7km)
No, I have each one dampered individually so after a round or two of adjusting, I can get them all the same.Interesting to see how she works with the third duct. Has that played havic on your static pressure at all?
I agree.That false top has to be effecting the overall output of the furnace.
If you are referring to me then, maybe, but back before I upgraded the insulation I only had to use ~700ish gallons of oil per winter. And that was with an old 1940 coal-burner-converted-to-oil furnace. The other thing is that my Yukon is rated the same as the Tundra for output (140k gross) and it will heat us right outta here on the same or, really, I think maybe less wood that what I have been using. But to be honest, when I say "less" wood, I have to admit that is after I modded the Yook for a cleaner burn.Either that, or your home isn't as tight as you think
Yah...ain't happening with the Tundra...very little heat output with coals, unless it is a firebox completely full of red screaming hot coals...and even then the fan cycles a good bit. The furnace room stays nice and warm though...80!? Feels cold when I go back upstairsWe coast on coals for quite some time
 OK let me give you the specs of what I have going on.
I agree with what others have said about the rating of the Tundra...way to high. The only way it is gonna heat 2500 sq ft is if you have a "super-insulated" home, or live a good bit further south than Ohio.
I need to get my paws on one of those infra-red cameras one of these days...I'm sure there are improvements to be had hereEither that, or your home isn't as tight as you think
Wow, is it that low? The Yook is 140k in and 112k out...at least what they claim. It does have a HUGE heat exchanger...54 sq ft total! That is why the furnace is so darn big (that's it in my avatar pic)140,000 btus is an input rating, I believe it's around 90,000 btu high output, and around 60,000 average output.
Nah...I got an ace-in-the-hole...if it gets too cold, flip the switch on the Yukon, BAM, heat!Luckily so far this winter had been nothing like the last, or you'd be in trouble. I'm rootin for you, but it sounds like you're running out of options.
Right, you just made my point. I used half that oil...BEFORE insulation upgrades, and your Tundra is keepin up fine, mine not so muchTo give you another example the past two years I used 1500gallons of oil each year. During the cold months it was exaclty 300 gallons on month
Nah, results before were even worse...I have been making some slow gains...besides I have tried all kind of different settings, to no avail...even not using itBrenn are you sure the controls you have on are not hurting you at all?
