Insulation and airsealing! I cannot stress it enough. We struggled for years, now it's not an issue. We have a Caddy, but currently there's a small coalbed and it's 75 in the house. It's 16 and dropping with chills in the single digits.
I meant as a way to get more heat...Max Caddy or HeatPro...
Bad joke I guess...
Anyone ever figure how to get more heat out of this thing? My biggest problem is the wood seems to coal up a lot when it gets about 20 degrees out.
Can you elaborate on what "more heat" means for you? (Does that mean longer between refills, your house is too cold in the morning, the coal stage doesn't make much heat, etc.?) The answer could be very different depending upon what you seek.
If you have too much coals, open the damper and throw a small split in the firebox. The split will kick out good heat for the hour that the coals burn down.
Just meant in general.I think bren was doing some. I was actually thinking about welding fins on to the outside of the heat tubes. Fins get hot air blows over them and boom more heat. Just my mind working.
During shoulder season I find more build up in the heat exchanger tubes and am finding cleaning them every two weeks helps with furnace output. The supplied cleaning tool is OK but find the Sooteater to not only be quicker but also do a better job. A few minutes with the sooteater and vacuum and done.
I'm trying to get a flue temp controller wired up to my Caddy furnace, and for the life of me can't seem to get it figured out. I bought the Omega CN418v-r1-r2 controller that 3fordasho used in his original posts. I configured it per the manual and the settings that he shared early in this thread, but there isn't any voltage being supplied through either the output or alarm terminals when measured on my multi-meter. The LED's are lit on the front saying that they should be giving power. Has anyone that uses this controller experienced this?
I'm starting to wonder the same thing. I'm writing an email to their support detailing my setup, and we'll see what they have to say. Hopefully I'm just missing something small.I use the same as what 3fordasho made. Haven't noticed anything like that. Maybe your controller is bad?
The output and alarm are just relay contacts, disconnect wiring to those terminals, with power off you should have continuity between the common and normally closed terminals (0 ohms on ohm meter) then power the unit up, adjust your set points so you get the output indicators (LEDs) on and then check for 0 ohms between the common and normally open terminals. If this checks out it's probably your wiring or maybe a setting - I don't recall if a setting could cause this malfunction or not.
Best thing you can do!Got that energy audit scheduled! Thanks for the motivation!
Out of curiosity, did you notice any difference in being able to keep your house humidified after sealing things up and insulating? We currently have TWO whole home humidifiers going and are putting 6-9 gallons of water a day into the air to keep it around the 40% RH. The colder it is outside the more water we put in the air. If RH drops below a certain level the humidistat will kick in the April Aire, but I don't like to run it if I don't have to as it cools down my supply temps some. This is why I prefer to use the stand alone humidifiers.
Yep, while we are still drafty in areas of the home, there's been a huge difference. We used to put gallons of water into the air, now we don't use a humidifier. It's 15 degrees out, 75 in the house and our humidity levels are at 30 percent now.
Wow, no kidding?! Seems like a lot. We don't use a humidifier at all and can maintain 40% normally. I do have the electric dryer vented to the basement in the winter though...heat and humidity, win win!that would be nice. Yesterday I literally put ~14 gallons in the house.....lol It's staying right at 40% though.![]()
FYI, it requires about 4700 Btu/hr every hour of the entire day to evaporate 14 gal. I'm sure you know that's a significant portion of the heat your Kuuma makes, especially this time of year which isn't the dead of winter yet.
(But maybe that's ok, since you have 10 yrs of firewood drying).![]()
![[Hearth.com] Everything Drolet Tundra - Heatmax... [Hearth.com] Everything Drolet Tundra - Heatmax...](https://www.hearth.com/talk/data/attachments/217/217907-1221559aba16490aa24dc48def96d1ea.jpg?hash=H4iTbRMsNx)
![[Hearth.com] Everything Drolet Tundra - Heatmax... [Hearth.com] Everything Drolet Tundra - Heatmax...](https://www.hearth.com/talk/data/attachments/217/217909-20c6343305c569edc0fc980f6d879e02.jpg?hash=oBSHMV6Eeg)
I would be concerned pumping 14 gallons a day into my old house that's for sure, it would be collecting as frost on windows, inside walls, all kinds of places you don't want it especially when outside temps warm up and it all melts. Hope your vapor barriers are in good shape. ( I suspect if they were, you would not need 14 gallons a day).
Don't ask me why. I couldn't believe it either.
It's not like I'm trying to keep it 60% RH or something. I don't see anything wrong with keeping humidity levels 35-40% in the winter, depending on how cold it is outside.
![[Hearth.com] Everything Drolet Tundra - Heatmax... [Hearth.com] Everything Drolet Tundra - Heatmax...](https://www.hearth.com/talk/data/attachments/217/217998-b047b5026a0069bf583d83972b6c018e.jpg?hash=DRms4w5KtF)
