Fast high flue temp post mortem
Feb 5, 2020
62
Scappoose, Oregon
Started a fire tonight as usual. Put a bigger piece of hardwood in there but nothing crazy. It must of really took off like never before because before the 20 minute mark, which is usually when I close the door, the fire alarm went off. I could smell hot metal and though the stove top was maybe 350F, the flue temp had rocketed to 1400F.
I turned the stove down and it stalled at at that temp and eventually cooled down, but not before a second fire alarm went off (I could strongly smell the hot metal but I never saw any smoke in the house.) While I wast monitoring, I noticed a section of the stove pipe (pictured below), was discolored (you can see at the top of the pic). (cont. below pic)
[Hearth.com] Fast high flue temp post mortem
I metered it and while the rest of the stove pipe had cooled, that section remained about 100 degrees hotter for a good while. Even now it's few degrees hotter than the areas above and below it at normal temps. A few questions:
1. Did I have a chimney fire? I checked outside and observed no flames or light from the outpipe. I clean the stove yearly in October but haven't yet this year because it's been unseasonably cold and wet. I was just waiting for a warmer day.
2. Do I need to replace that section of pipe before having another fire?
3. What could have caused that to get so hot so quick? A pitchy piece of wood? Just really dry?
I thought I'd share here and see.
Definitely clean the chimney and inspect that pipe before you have another fire. It’s not getting any warmer out. Why are you walking away from a stove with an open door, let alone leaving the door open for 20 minutes?
It could have been a fire but at that temp its not a given. Just clean it and check things out
Why leave the door open 20 minutes? Will the fire not stay lit if you keep it shut?
startup fires can vary with how quickly they take off. I’ve had some that seem to take a while and some I walk away from for a few minutes and it’s and inferno in no time. While I keep door just cracked open, it catches the latch a little bit. Definitely don’t leave it where a log could roll out of stove.
Open is a poor choice of words. Closed but latch down so cracked a 1/2".
Probably nothing really bad happened, but definitely a puckering moment. Revisit rule 1- never leave the room with a stove door open, and on the latch is still open. We've all pretty much been there, its no fun. Stay warm.
Yeah, one should never leave the room with the stove door ajar. It's too easy to get distracted. A good idea is to set a timer for 5 or 10 minutes that loudly reminds one to attend the stove. A digital flue probe with an alarm is also a very good idea. It's saved me from a space out more than once.
Reactions: stovelark
I set alarms and I'm typically in and out of the room doing things but noted, and for shorter intervals. I'll look into the digital flue probe too.
