I bought some pellets that burned good at first and I suppose they still burn good but the flame is out of control high. I decided to mess with the feed rate to see if that will help but I have no idea what I'm doing?
The directions only say to move the feed rate to a higher setting? The manual also says:
Used to change the feed rate
trims in ¼ second increments for all feed settings. When this
button is pressed, all the light will light up on the Heat Output
Indicator except for the one that shows the current setting; the
default setting is the number 4 light. To adjust the setting hold
the Feed Rate Trim button down and press the Heat Level up or
down buttons to adjust the setting.
What does this mean? If the default is 4 and I move it to 3 do more or less pellets get fed? It's not very descriptive in the manual. Anyway, I tried to mess with the feed rate last night and I gave the stove less air and this morning it was a disaster. I had about 1/2 inch solid brick on the bottom of the burn pot and the burn pot was full of pellets this morning on top of the clinkers (I'm surprised the stove didn't shut off).
Can someone explain what feed rate is to me?
Thanks!
Thanks!
