All....I had a Lopi 1750i installed last week. This morning was my first burn knowing I was going to be home for the day. I wanted to be around to watch over the stove and get used to the way it operates. Upon reading many hours and countless treads I was able to start a top down fire with little effort. I used some 2x4's that I split into small slices on top of some splits. It worked like a charm. I had a good burn with the door slightly ajar for three hours to season the paint as per the manufacturer. After that I closed the door and closed the damper just about all the way. (including the bypass that Lopi has...such a great feature) The stove hovered around 500-550 with a half load of sycamore spits. It appears that sycamore burns real hot and fast. I had three splits on the coal base and they only lasted 2 hours. OK....so I have heat and a s-load at that. My home is 1700 sq ft and my stove is heating it like no tomorrow. In the room that the stove is in 20x15 it is an easy 80-85 deg. The other rooms are at 77 downstairs. Upstairs is also 78 deg.. My wife has changed into shorts and a tank top. She is laughing saying that we are making Margaretha's tonight and sitting tub side with our feet in the water. OK..enough with the humor. I have dialed my stove down to no draft at all. (flue lever in all the way) I have a hot coal base and little fire (no secondary). The stove temp is 350-400. It is starting to feel better but temps are still in the 78-82 range in the house. How do you get the temps down in the house...open windows for a draft? Is it OK to run the stove between 3-400 without the secondaries burning?
I never thought I would be saying I have too much heat....lol.
This Lopi is a heat machine. All I have to do now is practice the art of heating with a wood stove. My first overnight burn should be fun....
