Now that I am installing radiant in the remainder of my house, and since it is going very slowly with all of the challenges in this house, my plan is to connect each circuit and use it. The problem is that as I turn of the air vents to each room that no longer needs hot air, I am adding allot of pressure to my furnace fan. When I start this latest run of radiant, my furnace will be about 65-70% blocked off.
I need a way to turn down the speed of my furnace fan, at some point this whole house unit will only need to heat one room. I still plan to use the water to air heat exchanger for this, so im thinking all I need to figure out is the fan speed problem, if this is possible.
Please keep in mind that this same furnace will be needed again for summer cooling, so the fan will have to be returned to normal state every season.
