Further adventures with my Castle Serenity: does anyone want a pin out of the ribbon cable going to the head unit?
mmcc
75
Northeast Ohio
I have a Castle Serenity with the older head unit (from 2018 I think). I've been forever battling with this thing to get it to ignite when the room it is in is cold. I have it in a detached workshop, and I don't run it every day, so it does tend to get cold.
I recently decided to try to get the signals that are going between the various sensors and motors and the head unit into my Home Assistant setup. To do this I added a breakout board to the ribbon cable and with help from AI and a multimeter, figured out what pin was doing what. I (mostly AI really) then programmed an ESP32 microcontroller to get that data into Home Assistant.
From this data, I've been able to determine that when cold the fuel to air mix is far too low. As a result, the flame is weak and the low temp alarm trips soon into the heating cycle.
My fix so far has been to set up stall 5 as a "choke" - I have the blower and exhaust voltages set the same as stall 1, and I start the unit in stall 5. I also prefill the burn pot. The stall setting has no impact on the ignition cycle, but once it goes into "heating" mode the stove is getting lots of pellets, little air, and not much heat blown away by the convection fan. I have Home Assistant (via an IR device) move it to stall 4 once the fire is well established.
In the future, I may add a rheostat plus a relay to bypass that rheostat in front of the exhaust blower so I can slow it down during the ignition cycle. I hope this would let me stop prefilling the burn pot. The stove settings don't allow for a change in the settings of the ignition cycle.
If anyone is interested, I can provide the pinout of the ribbon cable and the code that is running in the ESP32.
Mess o' wires and dashboard from Home Assistant shown below.
[Hearth.com] Further adventures with my Castle Serenity: does anyone want a pin out of the ribbon cable going to the head unit?
