Hello Everyone:
I spent several months trying to buy a gasket for the Piazzetta Smoke Chamber Cover with no luck. The distributer sent what they thought was right but it was too thick and with the tolerances so narrow on the cover it wouldn't fit. Finally the word came back that Piazzetta doesn't make the gasket any more, with the suggestion that a hi-temp RTV silicone caulking be used. Here are the instructions the distributor sent:
"A thin layer of high temp RTV silicon (sic) approximately 1/32-1/16” x3/8” be applied to the cover door perimeter and allowed to cure for several hours. After the silicon is cured the cover can be reinstalled."
My guess is letting it cure unmounted is to facilitate future removal.
I found 2 hi-temp ones, one good up to 450˚ and the other to 650˚. I used 650˚.
Hope this helps anyone in the same predicament.
Cheers, BillX
Cheers, BillX
![[Hearth.com] Gasket not available for Smoke Chamber Cover on Piazzetta [Hearth.com] Gasket not available for Smoke Chamber Cover on Piazzetta](https://www.hearth.com/talk/data/attachments/200/200472-7473fabc99b215a1756359a757045396.jpg?hash=MMc27fpaAQ)
