Grout or caulk around new tiled hearth
OutdoorsBen
1
Mass
I just finished replacing my floor and putting atile hearth in. Since it meets wood on three sides does anyone have a suggestion to use caulk or grout. As we know the grout will crack with movement of the wood floor. I am hoping to minimize future maintenance. Any thoughts?
Post pics of your setup
I did grout with no sealant, but i have angle iron along the edge of the raised hearth.
We are at the same point with our stone hearth. my plan was to grout down to within 1/8" of the floor and then caulk to the floor to allow for movement. you probably have cleaner lines with tile than stones and smaller grout spaces. I don't know anything about the flexible grout but would be surprised to see them work as advertised. even if your on a concrete slab wood moves alot with humidity changes.
I have a black granite tile hearth with a pedestal. The edges are very defined. I framed it with three pieces of oak that matches the floor, with two 45 degree, mitered I guess you'd call it, joints. It wound up being so tight I didn't feel I needed a sealer. I did put some black caulk around the gap where it met the pedestal (a piece of sparky stuff might not be good getting in there.
When I did mine the manufacturer of the grout also had a color-matched caulk available. I bought one tube and put it along the joints that met the wall etc.
