You might like the awd system in it now that you actually have a contact patch on your tires. It really is pretty good i would choose it over any of my 4x4s in the snow untill it gets to 6" or so. At that point you need more ground clearance than the escape has.dropped Escape tire pressure to apx38 mpg at 27. for hauling stuff I have a pair of F250's a gasser and diesel , combined with a 5t trailer and the 6x10 trailer or a little 4x8 that has no problem with a 1/2T on it.
Agreed. I love AWD in the snow. Way better on-road than any 4x4.You might like the awd system in it now that you actually have a contact patch on your tires. It really is pretty good i would choose it over any of my 4x4s in the snow untill it gets to 6" or so. At that point you need more ground clearance than the escape has.
Only if the 4x4 has limted slip or lockers.Agreed. I love AWD in the snow. Way better on-road than any 4x4.
4x4 still wins once you leave the road, tho.
lol... who would buy one without!Only if the 4x4 has limted slip or lockers.
Lots of people dont know the difference or care most people will never use itlol... who would buy one without!
My current truck has the posi 3.92 diffs, a special order item from Ram, that I can't believe every person doesn't order.
more like a rear wheel assist system fully automatic - which I am not fond of- the couple times last winter when it was on and I did not know ( there is no indicator or anything else that gives any idea) it i had set the cruise control and then it kicked off there by reducing the power drag and suddely I am doing around 75 it was set at 65. as it is self engaging and dis-engaging things get a bit squirmy on the back roads to my home- at the time tire pressure was around 30psi as I had just gotten the unit. I am very familiar with 4x4 both the current offerings on my trucks and true 4x4 from years gone by. ( not something you would want on city streets).You might like the awd system in it now that you actually have a contact patch on your tires. It really is pretty good i would choose it over any of my 4x4s in the snow untill it gets to 6" or so. At that point you need more ground clearance than the escape has.
Do you have the intelligent 4wd or the active awd system? From what you are describing i am guessing it is the 4wd system which is basically an auto 4wd that dimply sends power to the rear when it detects slipping. The awd system regulates power to all 4 wheels not just front and back. There is a screen you can go to to watch the distribution. With our awd you really dont feel any engagement or disengagement. You just have traction. And btw i am pretty sure 30psi is to low.more like a rear wheel assist system fully automatic - which I am not fond of- the couple times last winter when it was on and I did not know ( there is no indicator or anything else that gives any idea) it i had set the cruise control and then it kicked off there by reducing the power drag and suddely I am doing around 75 it was set at 65. as it is self engaging and dis-engaging things get a bit squirmy on the back roads to my home- at the time tire pressure was around 30psi as I had just gotten the unit. I am very familiar with 4x4 both the current offerings on my trucks and true 4x4 from years gone by. ( not something you would want on city streets).
No budget issues, here... but I still wouldn't buy a new truck. It's just a complete waste of money, IMO. I ordered the last one thru Chrysler Capital, they have what must be tens of thousands of them, off 2-year leases, on constant auction to dealers. I was able to walk in there and basically give the exactly laundry list of features I wanted, and my dealer ordered one in with that exact configuration. It had about 9k miles on it, and I saved about $17k over the price of buying new, a full third of the MSRP!Wish I had some taller gears in my truck. Budget doesnt allow me to order a new truck. The gears are really needed in the mountains. I almost never get to use 4th gear (OD).
Im leaning that way right now. Some of the leases have you paying 20K before giving it back and starting over. I can get what i want buying for 30k, for a truck that was 45k, 2-5 thousand miles ago in a year or 2 old. , so im thinking may as well buy it and have something to sell if i want to upgrade in a few years.No budget issues, here... but I still wouldn't buy a new truck. It's just a complete waste of money, IMO. o.
For what i use it for it is fine. Thought about one of those Prius ( not a fan of the mfg.)Too pricy for what they are and no towing ability to speak of.Deleting emissions is not grandfathered in. You may not need tested but it is against federal law to remove emmisions equipment.16 Escape - ford calls both the 4wd and the steering system adaptive- I just can't find who or what it is adapted to.For what i use it for it is fine. Thought about one of those Prius ( not a fan of the mfg.)Too pricy for what they are and no towing ability to speak of.
Buying off lease- is a good bet. If you can cut out the dealer in the middle. From what I could see around my parts off lease wasn't that great.
Getting back to the op I had a 99 F150 ( bought new) set up as a heavy 1/2ton - was a good truck for me at the time. The usage on it was similar to what you spoke of. For the heavy work I had a 80's f350 6.9 diesel and when that frame went south ( around 2000) then a 99 f350 V10. At the time diesel fuel pricing was way above gas. I now have a 04 F250 fully deleted emission wise 6.0 diesel - I am not in a metro area and so this is grandfathered in for a couple more model years after 2004 EPA wise. The extra 10cents a gallon is offset by almost double the mileage of the V10 gasser ( that truck was a real beast- current owner has the same attitude about it). Trucks for me are for work/ hauling- I have not been following how those little displacement engines in the 150s have been holding up. Course I am still old school -" No Replacement for Displacement".
I do not think there is anything out there that dosen't have some sort of issue- any mfg.
Most of the stuff I looked at, off 2 year lease, had 12k - 14k miles on it. Mine coming in at 9k miles was just a bonus, definitely not the norm.Im leaning that way right now. Some of the leases have you paying 20K before giving it back and starting over. I can get what i want buying for 30k, for a truck that was 45k, 2-5 thousand miles ago in a year or 2 old. , so im thinking may as well buy it and have something to sell if i want to upgrade in a few years.
Till it gets caught at inspection and you have to put it all back to make it legal to drive. That is if your state has inspections. If it does even without an emissions test they are supposed to do a visual inspection to make sure all components are there.The epa can eat all the rat tails they want, it won’t make any difference to those of us who don’t want it on there. Claim what you want, the crap they put in new vehicles keeps them from getting decent mileage and power. My truck benefited from the removal and the car doesn’t have half of it to start with(gotta love it when the mfg doesn’t use egr), and the second cat has been removed for a big gain in tq and mileage. I have a turbo for it, but need to get an artermarket computer for it to use the turbo.
No difference. Even 10 to 20k, id consider practically a new truck depending on how it was maintained.But other than retaining the new carpet smell, I'm not really sure how much a difference of 3k - 5k miles matters today. .
Everyone that wrenches on cars has a 'buddy' with access to the tax stickers to put on the windshield. It has been that way forever.Till it gets caught at inspection and you have to put it all back to make it legal to drive. That is if your state has inspections. If it does even without an emissions test they are supposed to do a visual inspection to make sure all components are there.
Yes but if you get caught not only do you get a ticket they loose their licenceEveryone that wrenches on cars has a 'buddy' with access to the tax stickers to put on the windshield. It has been that way forever.
![[Hearth.com] Half-ton pickup redux [Hearth.com] Half-ton pickup redux](https://www.hearth.com/talk/data/attachments/245/245879-e67c757f6b240356399cd118ccd90205.jpg?hash=-XuXXNIhy5)
This truck was listed as a work truck but has a lot of extra options. Yes AC is standard and its ice cold.It has powerBeing a manual transmission fanatic I would have bought it but the frame had quite a bit of rust. Does the 2015 work truck have crank windows? Probably air conditioning is standard. In the 2005 Silverado and Sierra work trucks I looked at there was none, and had crank windows.
