Harbor Freight Trailer build
BigV
139
Akron, OH
I was in the market to find a smaller trailer for use around the yard, specifically to throw wood into while splitting to minimize handling. After looking around at used trailers I decided to build my own. I started with a Harbor Freight trailer kit that was $350.00 and used a 20% off coupon. Final cost $279.99. The trailer has 12” tires, measures 48” X 96” and has a weight capacity of 1720 pounds.
[Hearth.com] Harbor Freight Trailer build
I spent another $112.00 on treated 4X8 ¾” plywood and ¾” deck rails along with misc. carriage bolts and a trailer jack.
Assembly was pretty straight forward and would have gone a little smother if I had looked at the directions….
The end result is a nice trailer that works perfect for it’s intended use and cost less than $380.00.
Looks a lot like mine. I put 16" tall sides made out of 1/2" treated and then a 1x4 a few inches above that for a total of 24" tall sides.
What are you pulling it with?
I have a Kawasaki Brute Force 750 I pull it with.
Great job. and an new trailer. cant beat that.
I was at Tractor Supply yesterday and saw this.
http://www.tractorsupply.com/ground...uty-utility-trailer-1-500-lb-capacity-3599561
It looks very heavy duty in person. All of the sides are removable and the front and back gates fold down.
Would be very nice to tow behind a garden tractor or an ATV.
I have one very similar. The problem is backing the trailer up. With the 2 front wheels turning in tandem with the toung, it is impossible to back up. I have to disconnect mine and pull it by hand.
Nice little wagon, but check out the reviews. Looks like the wheel bearings suck.
Yeah I saw that before I went to check them out in person. You can buy much higher quality bearings from Mcmaster Carr and be set.
I was going to build one, but after looking at that one I would have $200 into steel and welding wire just to build it not counting an axle.
Backing a wagon is an art I never could master. I can back a trailer anywhere, but am less than worthless when it comes to a wagon.
It's not impossible. You just need re-training! I grew up on a farm and pushed wagons backwards daily! Sometimes, especially if we felt like showing off :rolleyes: , we would line up a loaded tandem pair of wagons for a straight shot, connect 'em and back 'em into the barns for overnight storage!
Many a tractor clutch fell victim to new farmhands learning to push those wagons backwards, <> .
How did you attach the verticals?
The A-Frame would spoil it for me. The hitch on my Big Bear must be further forward/under the ATV than on yours. With an A-frame like my 5X8 I have virtually no turn room without the frame getting into my rear tires. Had I thought ahead and bought the cheaper, lighter capacity 5X8 with a straight tongue I could use it behind the ATV. I bought the heavier rated A-frame and it's useless with the 4 wheeler.
The frame has sections to allow for the uprights. The 4X8 sheet of plywood needs to be cut in those areas for the uprights to slide in. Then a carriage bolt attaches them to the frame.
I put an aftermarket hitch on my Brute Force 750.
It works great for pulling any trailer.
I had to extend my hitch out a little too in order to deal with the A-frame.
Built a Reese style receiver for mine to avoid the tires getting in the way. It accepts the hitch and the skidder I fabbed. I have since mod'd it a bit so that it attaches to 3 points on the frame. I think you would pull the bike in 1/2 before it detached.
  • [Hearth.com] Harbor Freight Trailer build
