This is my first season using the stove, as some of you may know or recall, Harman basically rebuilt my stove a few weeks ago due to multiple issues which basically rendered it useless out of the factory (quality issues under new management?). Now, that we are up and running, I am trying to assess what the true expected capacity of the stove and its limits – or maybe my install is not so solid causing other problems.
Here is my setup: the house was built in 2008 and is rather tight, no drafts. It is almost 5000SQF in total (main floor and second are 4300). The stove is side vented by going up about 4 feet and then horizontal for about 6 feet. It replaced a propane gas “decorative” fire place. I do have an OAK.
The stove is installed on the main floor with a very open plan and has multiple stairways to the second floor. When the temp is down to 20s-30s outside, I find its heating my entire house to a comfortable 74. However, when we go down to the single digits – it was struggling to keep the family room at 72-73 running on full and parts of the house dropped to 65-67. My propane furnace kicked in when it got down to 70 across the hall and was helping the stove. I have a heat pump on the second floor – I think it’s getting some help as it was not constantly on emergency heat as last year. So is this normal, given the size of my house and setup? Or should I see more heat from the stove?
I am burning Hamer and Truman pellets – I find that I cannot take the burn rate all the way up to 4. If I do that, I get a lot of unburned pellets in my ash tray and the flame gets very dirty, especially overnight as I may get a full tray of unburned pellets. The max burn rate I can run with good results is 3, but it seems I get less heat by doing that. I scrape the burn pot every time I put pellets in – about twice a day – two bags a day these days. Is this normal? The stove and vent are clean. It almost seems the stove cant burn at a high burn on 4 without overrunning itself. My dealer said that the OAK may be confusing it as its bringing in very cold air during the night impacting the combustion. it also sounds my vent is not ideal. Is that true?
My OAK is right next to the vent, same level. The vent terminates sticking out about a foot outside and down with termination cap. The vent termination is only a foot away from my siding and one of the windows – so I am getting some soot on the house and the top of my window. Is this normal? Should I extend/modify the vent? How do you clean the siding from the soot? How damaging is this?
Thanks for all the help guys, this forum is great. Wish I found it before the install and before my dealer left the building and the business! We need more pellet smart people around, guiding newbies like me
