Hello,
Looking to clarify a point on some posts I have seen on his forum regarding a rattly blower motor which has turned into a squeal at times. Those posts have been closed so I can not post my question directly on them.
There are two fans on my insert. A horizontal cage fan on the bottom and a open blade fan up near the exhaust. Someone mentioned that these fans can be lubricated. I have never read this before and the maintenance guide does not show this. Obviously, I would like to try and lubricate them before I have to replace a part. Though I think that the squeal means I have waited too long and the bearings are toast.
Since I can not run the stove outside of the fireplace, I am unsure which fan motor is noisey & would need to be checked and replaced. My rattly bearing noise/squeal only happens when the fan speed is on medium to high. I am making an assumption that the barrel fan is the culprit, since this seems to be what controls the volume of air coming out of the front. I have had an issue with the fan on the exhaust side many years ago and took care of that with a good cleaning and refitment so it did not spin against the housing.
Any help would be greatly appreciated.
Thank You,
Joe
Thank You,
Joe
