I have a 2008 Harman Accentra FS which has been flawless. Over the last two days with this extreme Arctic outbreak; -15 this AM. I notice the top of the stove was not hot at all, almost cool to the touch. Also, a large amount of ash and unburned pellets starting building up in the burn pot. The ash pan is almost 100% full after burning about 17 bags since the last cleaning a week ago. I have the feed rate on 4, this never changes and I crank the stove temp to 85 with the blower on high.
I clean this stove every week, however, I have not cleaned the flu since the big cleaning in October. I have put through 108 bags of LGs since then. I plan to do this this morning for sure.
Also, when I went to pull apart this morning, I noticed that it looked like someone painted a black lacquer on the inside bottom panel of the door and the same thing under the center of the ash pan when I removed it. And there was almost no ash in at the bottom on either side of the ash pan, usually, there is quite a bit.
Any ideas on this one?
Thanks!
Thanks!
